2010-05-03
04:49 PM
2023-05-26
03:23 PM
Rubia Torres
2010-05-03 10:55 PM
2010-05-03 11:24 PM
Erika wrote:I really like the option to be able to set all uncut lines to one line weight without the hassle of going into individual object settings! Thank you for that. Using that, I can set it to the lightest line weight I plan on using, then I can proceed to using fill and lines in order to show my darker ones, works out pretty well.
Ah, that is a different question.
The program will not adjust pen weights based on how far away an element is from the marker cutting plane. You can set what is called a marked distance line on the elevation marker settings and then have the option of a pen for all elements beyond.
You can also use the fill tool or lines to make more distance distinctions.
2010-05-04 01:54 AM
allegronea wrote:No, it does not seem you understand yet what Erika is trying to say about how pen sets work. You're making a very simple concept much more difficult...
Is there a way where you can do the above, working with the same wall in each elevation, and change its uncut line weight in the South Elevation to pen 5, and change its uncut line weight in the East Elevation to pen 6??
2010-05-04 05:38 PM
Karl wrote:Alright I see, so whatever # pen you assign to a certain object, its going to stay that way no matter what view you are using, but you can change how that pen # appears in each view.allegronea wrote:No, it does not seem you understand yet what Erika is trying to say about how pen sets work. You're making a very simple concept much more difficult...
The uncut line would always be pen 5 (sic) ... but that pen would display differently in different pen sets depending on your needs.
That said: you should not be using and modifying pens 1 through 10 for your non-library elements, as those are the default pens used throughout the library. If you change them, then your library parts will all display differently as well.
Stay clear of pens 1 through 10 and pens 19 (international) and 91 (US).
The most general method of managing pens is to assign pens by function. So perhaps pen 23 (e.g.) is your wall contour line. That pen might be a color for your working views and yet different for your different drawings - perhaps black for most drawings and gray for certain drawings. The weight might change based on the drawing type or scale. You might have a pen set for elevations, presentation plans and enlarged wall sections that has pen 23 as a heavier weight than it appears in the pen set that you assign to key plans, electrical plans, etc.
2010-05-04 06:06 PM
allegronea wrote:For the most productivity, you would not be changing much of anything after it is drawn. Each tool has default settings that 'stick' with the tool when the file is saved. Thus, part of creating a custom template is going through each tool and setting default pens, fills, materials etc for everything according to your needs.
Is there a way you can set what pens you want to appear on say your wall cut lines, before you draw them? Or are all pen changes made after something is drawn?
2010-05-04 08:03 PM
Karl wrote:Ah, alright then I see where your coming from. So a lot of this has to come from experience with your line weights and more importantly experience with your plotter and how it prints those line weights.. once that is figured out you can really get a handle on how things will be printed and what settings you can make before hand as your default.
But, of course, you will model many different kinds of walls. This is where you move beyond just the tool defaults to Favorites, which also memorize these things. (Or you can use 'visual favorites', where you use the eyedropper to pick up the attributes of existing building elements which switches the tool to whatever created the element and with all matching settings.)
HTH,
2010-05-05 01:06 AM
allegronea wrote:Once you change anything in a penset, even one pen color note that the name of the active penset is now CUSTOM. This means that at any point when you want to save changes you have made click on the STORE AS button. You will then have the choice to overwrite an existing penset or give it a new name starting a new penset.
In order to make a new pen set, do you have to change a current pen within an existing pen set in order to overwrite an existing or make a new one? .
allegronea wrote:To reinforce the solution, you must
And say I want to make my floor plan cut walls that are currently pen 5 on my first floor plan grey on my second floor plan. Would you advise making an entirely new pen to use for your walls? I ask this because if I'm currently using a pen that I use fairly frequently and change it to display differently on a different view... when I go to use that pen once again on the view that I altered it.. it obviously isn't the same pen anymore.
Anthony
2010-05-05 05:21 PM
Erika wrote:I guess I should have used a different example.. that is by no means what I wanted to do.. it was just something easy to interpret to you in terms of what I was trying to do (in a general sense). However, when this situation actually
Your example of having a different pen color for different floors, well I can't help asking WHY? That aside, you could either make separate pensets for each floor, or use a different pen for the second floor walls.
But, I am back to wondering WHY you want different colored walls for each floor/story?
2010-05-05 05:47 PM
2010-05-05 06:39 PM
