2006-11-15 04:53 PM
2006-12-14 09:16 PM
2006-12-14 09:20 PM
2007-01-09 05:20 PM
2007-01-09 05:57 PM
PivoArch wrote:
What is the best way to keep the attributes in order. Becuase nothing is more frustrating than having a material or linetype fall in two different spots in two different models.
2007-01-09 06:03 PM
Laura wrote:I use the same approach... I really want to put buzzers in people's chairs for when they mess with the attributes!PivoArch wrote:
I just issue a proclamation, to the effect "DO NOT ALTER/DELETE ATTRIBUTES. If you do, you die" -- this seems to work in most cases, but there are always exceptions...
2007-01-09 06:05 PM
PivoArch wrote:Can't you set it to "Show on all stories" in its settings menu?
Ok, not to sound ungrateful or anything because the firerated object is great. I just have one question. If you use it on a wall that spans multiple stories, the object will show up on the lowest story the wall is visible on. Is there a way to make it show up on All Stories that the wall is visible on. This is in Reference to the NEO_FireWall object. Thanks.
Also, how does everyone feel about existing and demo models for renovation work. What is the best workflow and how do you keep them clean..I've had a few ways to do them... none of them are clean!
2007-01-09 07:47 PM
PivoArch wrote:The standard approach is using layers. Typically with .D, .E, and .N extensions for easier management. Most firms I know only need one demo layer and a few existing layers. It is usually not necessary to model the existing building in great detail and most demoed items can go on the demo wall layer (A-WALL.D per NCS)
And since I am at it. What is the best way to keep the attributes in order. Becuase nothing is more frustrating than having a material or linetype fall in two different spots in two different models.I train people how to add attributes (and establish naming conventions). I also train them NOT to delete the standard ones (office standards that is, which may or may not include all the GS stuff).
2007-01-11 08:35 PM
TomWaltz wrote:Yes you can, but then is actually shows up on all stories. Even if the wall does not.
2007-01-11 08:48 PM
PivoArch wrote:TomWaltz wrote:Yes you can, but then is actually shows up on all stories. Even if the wall does not.
2007-01-11 09:09 PM
Matthew wrote:...and this I will do, too, once Implementation is "complete" and we have a better idea of what we do and do not need.
