Tim Ball
Fill naming
I like to change the names of my fills from the factory settings, so that the order they appear in aligns with my layer and composite naming system.
However there seem to be two sets of fills and the bottom set stay in their own group.
What's the difference and why?
Tim Ball
AC26, iMac
User since V5
1 Reply 1
the first set - outlined in pale red - use an internal mathematical algorithm to describe the vector fill (which can only be customised according to size and rotation)
the second set - outlined in pale yellow - use a vectorial image which is then 'tiled' to produce the fill (which can be anything you want by copying and pasting from the plan window)
they will always be ordered into separate groups
bill
