the first set - outlined in pale red - use an internal mathematical algorithm to describe the vector fill (which can only be customised according to size and rotation)
the second set - outlined in pale yellow - use a vectorial image which is then 'tiled' to produce the fill (which can be anything you want by copying and pasting from the plan window)
