Building Materials - hide fills in 2d plan
Gabriel Cristea
I've recently added in a few new building materials and assigned them to the wall composites.
My goal now is to have the 2D / GA plan show minimal detail, just a solid colour instead of a hatch. Current view after the building material changes:
Before this change, the walls used to look like this (ignore the thicker lines, this is a screenshot from an exported drawing):
Any way I can achieve this without having to simplify my building materials or wall composites?
Operating system used: Windows 10
10 REPLIES 10
CosminF
You might want to look into graphic overrides - you can override the cut fill and cut fill pens as you wish and save it without affecting the original drawing.
https://help.graphisoft.com/AC/24/int/_AC24_Help/050_ViewsVB/050_ViewsVB-134.htm
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
I've tried that and it somewhat works but it only appears to allow me to set one colour for the entire wall, it cannot have multiple. I tried to create 3 separate rules, 1 for plasterboard, 1 for timber frame and 1 for insulation all with different colours but the graphic override only takes the colour of 1 of them into account at a time.
It should be able to do your intended overrides. Can you maybe share one of the rules you made?
This is one of the rules, and below you have all 3 rules. You can see the different colors set as examples; in this configuration, the walls are pale orange, ignoring the green and black overrides.
CosminF
Thank you!
I tried to replicate your situation and I'm facing the same issues:
After some searching I have found this wishlist item, and apparently this is not a current feature, and has been requested previously: https://community.graphisoft.com/t5/Visualization/Feature-request-Graphic-Override-for-building-mate...
That's really disappointing and defeats the purpose of the building materials... Thanks for your time in trying to help find a solution.
You can opt to only override the fills and not the colours
Apple M1 Max 32 GB Ventura
AC27
Sorry deleted.
AC 28 INT 5200/WIN 11
Lingwisyer
Guru
As Cuba has shown, Graphic Overrides affect elements in their entirety, so you cannot override both the Fill and the Pen else the Composite will look uniform. Ideally, the different materials that make up your Composite use diffferent Fill Foreground Pens allowing you to control the colours within your Pen Set after you've overriden the Fill in your Graphic Override.
Ling.
Setup info provided by author
