2006-06-23
05:32 PM
2023-05-30
01:01 PM
Rubia Torres
2006-06-23 05:55 PM
Pete wrote:Why would you copy/explode your footings? Are they walls? I found a slab set to "Show one story up" would behave better.
Now that I'm setting up a new template for AC10, the question of location for foundation elements once again arises.
Through AC8.1 my foundation was on a story below the basement. I had to copy, paste to the basement story, and explode the foundation walls that I wanted to show with basement walls.
In AC9, various layer combinations allowed the foundation walls to be on the same story as basement walls, but still needed some tweaking.
Now in AC10 we have multi-story walls and I am scratching my head again. What are others doing?
2006-06-23 06:10 PM
2006-06-24 12:49 AM
Pete wrote:I think this is a great application for the profile wall tool and I have a footing, stem-wall, mud sill profile I have been using on a couple of project. I would use slabs for foundations as well primarily for the level dimension tool. I hope soon Graphisoft will give us "gravity" for walls which will allow the level dimension to be used with walls. It is great for those sloped sites with stepped foundations....
It seems, in AC10, that some are using the new custom wall profile to model foundations that include a footing, wall, sill, brick ledge, etc.. Is this productive?
Thanks,
2006-06-28 04:10 AM
2006-06-28 04:29 AM
2008-05-29 01:01 AM
s2art wrote:Could describe this in more detail? Im not sure what you mean "add a node" and change the profile. Do you mean multiple profiles can be assigned to the same foundation object? A little clarity would be helpful
logandesigns
If you have stepped foundations, just have profiles of varying heights, add a node to your slab edge where the height changes, and assign profiles accordingly.
2008-05-29 01:14 AM
2008-05-29 01:19 AM
s2art wrote:Wow! Impressive! Thanks! This saves me so much time! (So I have a government department named after me in NZ? Nice.)
Lindsay
(LINZ = Land Information New Zealand)
Yes, multiple foundation profiles can be used on a single object. Add a node by selecting the slab, use the pet pallette on an edge to insert a new point along that edge. Note that if you do this to a slab that already has a foundation accessory connected to it you may have to use the "edit edges" function in the tool to reassign profiles that occur after the added node point.
Hope this makes sense.
