Betencorte
Get properties based on building material on expressions
I would like to create a property for the building material (let's say the cost per cubic meter) and then, if the element have this material, or the composite have this material, i want to get this property, e.g. when the element composite have the building material "clay brick", use the "core volume" and divide by the "cost/m³" property set in the building material.
Is there any way of referencing properties like that?
0 Replies 0
