‎2007-11-15 08:08 PM
‎2007-11-15 09:01 PM
Rod wrote:Oh Ya. 1) I have found no work-around for (in AC10, the grid lines were -- let's say -- "flakey", but at least once you got them where you wanted them, they stayed put). In AC11, it seems to be totally unpredictable and random, and 2) try entering .001 as the Staggering parameter (under the Section/Elevation Panel of the Grid Element dialog) -- it doesn't like zero.
Has anyone had similar problems with the grid tool:
1) selectively permitting grids to disappear in section/elevations
2) total staggering of the markers in section and elevation.
‎2007-11-15 11:18 PM
‎2007-11-19 10:46 AM
Rod wrote:Have you tried switching off Auto staggering in the Section/Elevation --> Grid Tool panel?
‎2007-11-19 11:18 AM
Rod wrote:I reproduced it and I admit it is a bug - and a very peculiar one...
‎2007-11-19 05:04 PM
‎2007-11-30 04:18 AM
‎2008-03-18 04:34 PM
‎2008-03-18 05:08 PM
Alice wrote:I have experienced both of these problems.
I also had issues with the Grid Tool (teamworked file, AC11), it was impossible to edit after initial insertion. We also had problems with dimension strings appearing (and then randomly reappearing) even though we had chosen to NOT show the dimensions in the settings.
Alice wrote:It's also frustrating that there are no Grid Tool settings within the IE Marker dialog (I don't want grids in my interior elevations)!!!
It's frustrating to suddnely see a random dimension string run acorss an interior elevation as you're printing your cd's.
‎2008-03-19 04:18 PM
