Hotlink module
Hi! Im an ArchiCAD beginner struggling with a hotlinked module. Is it possible to move/rotate/mirror an already hotlinked module? and how? because once ive placed one, its stuck there, cant move it/copy or anything.
Thanks!!
3 Replies 3
Erwin Edel
You need to enable groups for your selection.
Edit > grouping > suspend groups
or ALT + G
or find the icon on your toolbar or use the Control Box palette (which is useful for other reasons too), which has enable/suspend groups on it.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Sweet, thanks alot!!
Rather then point a new topic about this topic.
I need a little help.
I have created two dwellings (Houses) and need to put them onto the master site plan.
The two houses have the same floor level on the ground floor. The issue is that one house is 3 stories and the other is only 2 stories.
House 01 - 2 stories (both 2.4m stud)
House 02 - 3 stories (ground an top stud is 2.5m, middle stud is 2.7m)
Now when i placed them onto the site plan things are showing in the wrong level
any advice would be great.
Thank you.
