Karol Argasinski
How to run BIMCloud via https protocol
Hi everyone,
Is it possible to run BIMCloud via safe https://
The platform that I am trying to configure it is MacOS.
Best,
Karol
OPENBIM does works!
ArchiCAD 22/23/24/25/26/27/28/29 INT &POL
AMD Ryzen 7 3700X, 128GB RAM, GeForce RTX 3070, Windows 11 Pro
MBP 14 M3 Max 16C/40G, 128GB, 2TB
http://www.bimfaktoria.pl/
5 Replies 5
Noemi Balogh
Hi Karol,
Yes, you can setup an HTTPS environment for your BIMcloud. What you need here is a well configured reverse proxy (by default BIMcloud components can communicate with each other via http only, so you need a middle layer to be able to setup such environment between Archicad clients and BIMcloud components).
An important note here is, that many people forget to give access both to the BIMcloud Manager and BIMcloud Server. If Archicad cannot communicate directly with both components, it first causes performance issues, and later can cause even error messages and failed operations while working in Teamwork.
You or your IT might be interested in our BIMcloud for IT Professionals training on the Graphisoft Learn portal, where you can learn more about the requirements: https://learn.graphisoft.com/user_catalog_class/show/23595
Noémi
Noémi Balogh
Staff Community Expert, Admin
Karol Argasinski
Noémi,
All I can see is info that I am unable to see training.
nbalogh wrote:
Hi Karol,
You or your IT might be interested in our BIMcloud for IT Professionals training on the Graphisoft Learn portal, where you can learn more about the requirements: https://learn.graphisoft.com/instructor_modules/list/23595
Noémi
OPENBIM does works!
Noemi Balogh
Thanks for the heads up! I shared the wrong link, sorry for that. I updated my original post, and share it here as well: https://learn.graphisoft.com/user_catalog_class/show/23595
Noémi
Noémi Balogh
skychiang
Hey Noemi, how can I set https in BIMclooud ? can you sshow me step by step? Even I enroll the Graphospft learning portal, it takes time to watch all videos, that will be too late for my schedule. Thansk a lot.
We have the same situation here. Just looking for a guide on how to set up as this should be set and forget so not really looking for training course.
Most likely companies will have external IT support and might be inconvenient and expensive to pay for their time taking the course.
