Mats Knutsson
I get stuck on this seemingly simple expression...
I have properties and want to drive values from combinations of these properties but I can't figure out how to. Any takers?
Br,
HP ZBook Fury 15,6 G8. 11gen i7-11800H 2.3GHz. 32 GB RAM. Nvidia RTX A3000 1GB. AC22-27 SWE.
1 Solution
I am not sure if it is applicable in this case, but I have found depending on the language version of Archicad or maybe your operating system, some need to use semi-colons as expression separators and others need to use commas.
Go to post
7 Replies 7
runxel
Hi Mats, if you mean like the little formula beneath try something along the lines of:
IFS (
    AND ( Type="A"; Material="yy";etc..); "100";
    AND ( Type="B"; Material="zz";etc..); "200";
Hope that helps!
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Mats Knutsson
Nope, tried that.
Yves
like this with a number type property
IFS ( AND ( {Property:Généralités/Type} = "A"; {Property:Généralités/Material} = "xx"; {Property:Généralités/Accessory} = "1" ); 100; AND ( {Property:Généralités/Type} = "B"; {Property:Généralités/Material} = "yy"; {Property:Généralités/Accessory} = "1" ); 200 )
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
Mats Knutsson
Got it to work. Thanks! Seems like the same code as Lucas suggested. I don't know went wrong earlier...
I get grey hair from the syntax and the editor....
Mats Knutsson
I've got that settled so it was something else. I must have missed something somewhere.
I will write to full expression (it will be quite massive) in a text editor and then paste it into AC.
Xandros
Do note, that the ifs function might have a limit. It does have one in excel and I wouldn't be suprised if it has one in ArchiCAD expressions too.
https://support.microsoft.com/en-GB/office/ifs-function-36329a26-37b2-467c-972b-4a39bd951d45
I once had this issue of a massive expression with a few hundred conditions. ArchiCAD performance will suffer noticeably!
If you reach more than the maximum you'll have to get creative on how to implement the expression(s) and how to improve performance again.
ArchiCAD 27 GER / Win10
Intel i9-9900K / 64GB RAM / nVidia GeForce RTX 2080 Ti
