Injecting only Cut fill/Symbol Line settings
I'm hoping that there is a way to inject the floor plan/section line settings only. I am working on a project that has Existing/Demo/New/Future walls with 2 different wall types (CMU and wood frame). The problem is that when i inject the properties from one wall to another i get all the floor plan/section line settings i want, but the heights of the walls and the layers both change.
The building that i am working on is 3 existing buildings pretty much touching (pre 1960's with seismic separations) eachother and the complexity of some of the attached areas that bring the spaces together is ridiculous.
I have the existing building model pretty well set, but now that the design is changing and im switching new walls to existing and existing to demo etc... it is becoming very time consuming to switch around these settings.
Laura Yanoviak
You can select all the walls that you want to change, and edit the floor plan/section line settings within the dialog -- only those parameters will change.
Link
You can also do it with favorites, as explained again here.
Link.
