Is there any systematically method to assign classification for ALL objects ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2025-02-14 03:37 AM - last edited on ā2025-02-14 03:40 AM by Barry Kelly
I would like to know if there is any method to select a classification system and assign classifications to all objects in a systematic way?
I have tried exporting a schedule (as an Excel file) and assigning classifications to all objects, then importing it using the "Import Property Values into Elements" option under "Interoperability". However, this method did not change the classifications of those objects.
Thank you!
Operating system used: Windows 10
Solved! Go to Solution.
- Labels:
Classifications & Properties
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2025-02-17 09:52 AM
That is why I like Find & Select.
You select all that you want and then 'Show selection in 3D'
But there is really no need if you find and select all walls with no classification.
Once they are selected, just add the classification in the wall settings.
Then find & select all railings with no classification and add classification.
Then all stairs.
I guess that is where Xandros is saying schedules are more powerful.
You can schedule all 3D elements that have no classification.
Then in the fields just add element type and classification.
Tick the 'Merge Items' box and you should have one item for stirs, one for railings, one for walls, etc.
Then just change the classification right there in the schedule and all of that element type will change.
So now I do agree with @Xandros that schedules can be more powerful.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2025-02-17 10:48 AM - edited ā2025-02-17 10:53 AM
This is why I like schedules:
I can add, remove, refine the criteria (you can do that with find/select, but need to resave your saved search, schedule just stays the way you last refined it), add other data to the schedule (layers, home story etc.) to help understand what I am seeing, I can play with switching between merging if uniform values only, or any value. I am not tied to what I see in a model or plan, I am working on the complete project. If I need to see the items, I can always ask the schedule to show on plan or 3D.
Ultimately it is good to have schedules to check the quality of your model: do I have unclassified elements? do I have elements in a classification system I don't wish to use etc. The schedule is there in you view map, you just need to load it. As with find and select you don't have a ready-made report.
And one more thing: sometimes find and select doesn't find the items a schedule does! For instance members of railings, curtain walls and stairs have their own classifications, and these don't get found with find and select, because that focuses on the classification of the entire railing or stair. But these are listed in a schedule. They are a pain to identify and fix though...
first ArchiCAD: 6.5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2025-02-16 06:06 PM
The best way to have your objects in the right classification is to have a base of favorites, and then if you need to change something start there but keep the "original" classification.
MERLO Website
Intel I9 13900K + NVIDIA 4090 RTX for Archicad 28
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2025-02-16 07:26 PM - edited ā2025-02-16 07:27 PM
You can assign a classification using expression and an addon. Here is a short video with an example of the worŠŗ
Structural engineer, developer of free addon for sync GDL param and properties
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2025-02-17 08:17 AM
Thank you for reply!
Actually, my task is to assign classifications to a model that is missing classifications for certain 3D objects. It is difficult for me to find, select, and assign the classifications one-by-one.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2025-02-17 08:47 AM
I am not sure that you can automatically assign a classification to elements that don't have a classification.
It could be deliberate that there is no classification.
But what you can do to help find them is set up a 'Find & Select' criteria looking for all or particular element types that have no classification.
Then you can select them and change them all at once.
Or you could set up Graphic Overrides to change the colour of of unclassified or incorrectly classified elements.
Then just select the ones with the overridden colour and amend them.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2025-02-17 09:08 AM
My method is to set up schedules. It is more powerful than find and select.
first ArchiCAD: 6.5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2025-02-17 09:18 AM
Yes, I think the schedule is a effective solution to identify the objects missing classification.
Then, is there any method to assign classification to those objects quickly?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2025-02-17 09:19 AM
Schedules work as well, but I would argue Find & Select is a little easier to adjust all of the 'not classified' elements all at once, rather than one by one in the schedule.
Plus you can see what it selects, rather than having to guess what is what in a schedule (not that that matters if you want all elements to be classified).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2025-02-17 09:23 AM - edited ā2025-02-17 09:44 AM
One by one in a schedule. EDIT - unless you can merge similar items.
Same with graphic overrides, you still have to select them to change them.
But Find & Select, selects them all for you and they can all be classified at the same time (if they are all to have the same classification).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2025-02-17 09:36 AM
You do not necessarily have to assign each individual element to a classification. You can also use āmerge itemsā to reclassify more elements at once.
Intel i9-9900K / 64GB RAM / nVidia GeForce RTX 2080 Ti
