vfrontiers
Layer Combo error?
Has anyone had this happen?
In the palette that allows you to switch layer combos.... I select a combo.. it changes to the proper layers, but the palette quickly changes back to CUSTOM...
If I open the Layer Dialog, it does NOT show any LAYER COMBO selected
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
vfrontiers
Sorry... I should mention this is in AC21
Duane
Visual Frontiers
AC3.14 - AC29
Laura Yanoviak
I believe that has happen to me -- I couldn't give you a explicit example, tho. I'll post back if it happens again.
