davdelven
ELEMENT ID MANAGER "FILE"
Hello,
Where can I find the "element ID manager" FILE in the computer installation ?
Thanks
David Delgado Vendrell
http://www.daviddelgado.cat
GIGABYTE AERO X16 16" AMD Ryzen AI 7 350 32GB 1TB SSD White Copilot+ RGB
Triple Monitor 16"+25"+32" Nvidia Geforce RTX 5060 8GB
SSD+HDD, Win11 Home - 64 ENG
AC18-AC28 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
I decided to not switch to the Subscription path, and stay with AC28 proprietary license. We'll see what the future brings us...
I don't think it is a file you are supposed to play with.
As far as I can tell it is here ...
C:\Users\your_user_name\AppData\Roaming\Graphisoft\EIDM Settings 20.6005\EIDM Settings.bin
You may have to unhide the APPDATA folder in the settings as it is a hidden system file.
I would recommend that you don't touch it unless you really know what you are doing.
