Project data & BIM
Layer combination confusion
700c
For some reason my interior elevations will only show the layer combination that's currently applied to the floor plan. If I try to change them to a different layer combination, the little exclamation point appears in the interior elevation tab, but nothing changes in the view. I've tried changing view settings for the interior elevations, but same issue. What am I missing?
13 REPLIES 13
Minh Nguyen
Graphisoft Alumni
christiandcdc wrote:
Minh,
I have been having this problem on some projects and not others. I found this thread and confirm the interior elevations will only show the layer combination that is on the open floor plan regardless of combination assigned to elevations. This in v23 with latest update 4006. The particular files are solo projects migrated up from v20 (but not all migrated files). Note the elevations are both migrated and newly created.
I'll have to go check my few from scratch v23 projects.
Thank you for sharing the issue!
Would it be possible for you to share with me a file that will demonstrate the issue after migration for a closer look (so preferably the v20 file you mentioned)?
Let me know here or via PM if you need a link to securely forward the file also!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Kate1
Did anyone figure out a solution? I've had this on a couple of different files since switching to A25.
Kate1
Did anyone find a solution? I've had this problem on several files. I open the IE and it instantly flicks off the IE layer combo and switches to the Floorplan layer combo. Sometimes for no reason it resets and starts working correctly, but I can't rely on that randomly happening when we need to get drawings out!! Thanks!
bryan8
I've dealt with this same issue, happens randomly on different projects. Hoping there's a solution to this?
Fortunately/Unfortunately for many Archicad glitches, I can clear my cache, restart the program, reopen the project, and the glitch goes away. But for this issue that doesn't seem to work...
