‎2020-04-18
01:50 PM
‎2023-05-30
12:35 PM
Rubia Torres
‎2020-04-20 11:29 AM
LucaP wrote:
BTW. Do you know if there is a wish for it?
‎2020-04-20 12:19 PM
‎2020-04-20 12:40 PM
‎2020-04-20 06:26 PM
poco2013 wrote:+1 As BIM develops I can see that category display filtering could become an essential part of the modelling process, particularly where you have sub-elements that you need to identify or check. As an example you might have a layer for "Frames", the ability to only display the bracing & columns would be helpful if other content in the Frames layer made it too cluttered to edit. The same could be useful to ensure categories have been correctly applied. There is a tradeoff here between the number of layers to separate elements or controlling visibility through categories and each project will find its own balance. At one extreme you have one layer called model and everything is displayed by category, at the other you have the historic methodology of enough layers and no categories.
I also agree that the layer based scheme is absolutely essential as currently used and must remain. But that there should be additional options and criteria based visibility sounds like a good one to me.
‎2022-09-06 03:28 PM
I made a product wish for this: Replace layers with classifications - Graphisoft Community
Please vote for it!
