Ahmed_K
Mentor
Layers VS categories
Hi all !
as archicad introduces categories and classification systems, is there a reason to stay with layers and layer combinations ?
showing and hiding Categories will be more BIM and more usefull, we set categories, and then we start working like always
Archicad 27
Windows 11 professional
14 Replies 14
LucaP wrote:
BTW. Do you know if there is a wish for it?
With regards to hiding elements with GO - 3 that I can see, but as with many wishes they seem to incorporate other wishes as well or started out as something else.
Just as this has gone a little of topic from the original post (probably my fault).
https://archicad-talk.graphisoft.com/viewtopic.php?f=25&t=56266
https://archicad-talk.graphisoft.com/viewtopic.php?f=28&t=53427
https://archicad-talk.graphisoft.com/viewtopic.php?f=27&t=67598
Maybe make a new clear wish (with a poll) if you really want this.
Ahmed_K
Mentor
And what to do if an element receives two or more classicitaions, meanwile it could be placed on a unique layer ?
Archicad 27
poco2013
Mentor
Presently, an element in Archicad can only be assigned only one classification (per classification group). but each classification can have multiple properties assigned to it. That why I like the GO rule based method for visibility as it allows the user to establish its own criteria or have multiple criterias for each plan.
I also agree that the layer based scheme is absolutely essential as currently used and must remain. But that there should be additional options and criteria based visibility sounds like a good one to me.
Gerry
Windows 11 - Visual Studio 2022; ArchiCAD 27
DGSketcher
Legend
+1 As BIM develops I can see that category display filtering could become an essential part of the modelling process, particularly where you have sub-elements that you need to identify or check. As an example you might have a layer for "Frames", the ability to only display the bracing & columns would be helpful if other content in the Frames layer made it too cluttered to edit. The same could be useful to ensure categories have been correctly applied. There is a tradeoff here between the number of layers to separate elements or controlling visibility through categories and each project will find its own balance. At one extreme you have one layer called model and everything is displayed by category, at the other you have the historic methodology of enough layers and no categories.
Mikko Lahti
I made a product wish for this: Replace layers with classifications - Graphisoft Community
Please vote for it!
Mikko Lahti - Helsinki, Finland
BIM specialist
Archicad user since 2004. Currently mainly using Archicad 27 and 29 FIN and INT versions on Windows 11 and MacOS computers.
