Project data & BIM
Layers in paperspace
When / if I notice on my layout a layer is on but should be off (or vica versa) I right click: open source view: then edit layer settings (cntrl L) and then got to the View Map, click on Settings: get current window's settings.
Is there a simpler / quicker way?
thanks,
Henry.
1 REPLY 1
Assign layer combinations to your views and edit the combos. This will maintain consistency and update all the views based on a revised layer combo at once.
