Llian
Material Code in Zone Tool
How do I change the material code for Wall, Floor and Ceiling, Base, etc ?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
3 Replies 3
Llian
I found it !
so.... where is it?
fabuxo wrote:
so.... where is it?
Generally all zone stamps by default have some parameters built in so you can list them in schedules. You can find them at the bottom of the parameters listed under 'Parameters for Listing'. Be aware these are manually entered and not based on what is shown on the model.
To get them to display on plan depends on the zone stamp you are using. Not all have the option to display material codes.
Hope that helps.
