Sergey K_
Maximum column height with custom top and bottom cut angles.
Good day to you, kind sirs and madams!
A column in Archicad has a listing parameter "Maximum height of the Column". It returns values correctly if a column is cut by a roof or is not. If I create a column with the top or bottom cut at a custom angle (set in column parameters), the parameter does not return any numeric value.
Is there any way to read maximum height of a column that has top or bottom with custom angles?
1 Reply 1
Rajesh Patil
I think with the help of "Classification & Properties" you can surly define required Property & extract the needful information. Do you mean finding height as mentioned in the sketch bellow?2021-09-17.png
Rajesh Patil
AC 09-27 | INT | WIN11 64
Dell Inspiron 7591, Core i9, 9880H 2.30GHz, 16.0GB, NVidia GeForce GTX1650, 4.0GB, SSD Internal 500GB, Dell SSD External 250GB
