Merge project info
Is it possible to merge the project info.
It works fine to merge the layout book. But all the project info is lost. This means that all the title blocks are practically empty and I have to retype it all. BUMMER!
OK. Found it!
Project Info can be exported as a .xml from the layout .pln, then imported into the model file or the merged file.
http://www.archicadwiki.com/Archicad_10/Project_Migration/AC_and_PM_files_into_a_single_AC10_file
