2011-12-10
05:54 PM
2023-05-26
03:22 PM
Rubia Torres
2011-12-10 06:46 PM
2011-12-10 08:24 PM
Karoline wrote:If you have a template file, merge it into your current project.
I can´t find the brick wall fill for illustrating the wall in my elevations. The only fill I have available in the wall default settings are the composite structure.
When I go into the element attributes: materials everyone comes up with "missing" in vectorial hatch. The the only thing I can choose is the fill type.
Why can´t I find more fills? I need the brick wall to show in my elevation. + edit it... Can´t find any similar posts or tips about downloading vectorial hatches or fill either. Please help me!
2011-12-11 02:30 PM
Djordje wrote:If you don't, open a New & Reset All new file (Command+Option N), which will open a new blank file with the default fills.
2011-12-12 04:49 AM
David wrote:... then save the blank file and merge it into your projectDjordje wrote:If you don't, open a New & Reset All new file (Command+Option N), which will open a new blank file with the default fills.
