Learn more
Modules Question
I am currently working in AC11 with the latest build, 1040. Is there a menu somewhere to check and see what the Master Layer for a hotlink module was? And if so can that be changed once the module has been placed?
Sorry if this has already been answered. I have been searching and reading a lot of the post but did not seem to find one close to my question. Thank You.
2 Replies 2
TomWaltz
Select the module, the click File > External Content > Hotlinked Module Settings... and you will get a small menu that looks like the one you used to place the module, specifically with its master layer.
Tom Waltz
Thank you Tom. Always an easy answer!!
