Project data & BIM
Parameter transfer of classification and properties not working - AC 27 BUG?
amh_caspar
Hi everyone,
I am trying to use the parameter transfer tool to transfer classification and properties from morph objects to other Building Elements.
At first in the Element Transfer settings I just had ticked the boxes for classification and properties but when this didn't work I ran a few tests with transfer all settings applied but still in every test the classification is not transferred. Other settings are transferring just fine. But Classification is not.
Is this is a bug? Or maybe someone has an idea why this isn't working.
Operating system used: Windows Windows 10 Pro
1 REPLY 1
Settings transfer works only from an element type (e.g., Morph) to an element of the same element type (another Morph).
Try the Edit Selection Set Dialog, (Edit > Element Settings > Edit Selection Set menu command or CTRL+SHIFT+T key combination).
In that Dialog, you can set the Classification and Properties for multiple elements of different element types.
Setup info provided by author
