lagodue
Printing a ghost layer?
One of my floor plans (storage above a kitchen ceiling) I now show as a second story with ghosted first floor. In PlotMaker, the ghosted story will not appear - only my second story specific lines and notes.
Am I missing something here? Shouldn't the ghosted lines show up in PlotMaker?
"Bob" - Church of the Sub-Genius
Graphisoft afficionado since 1993
6 Replies 6
TomWaltz
Nope. Ghost stories do not appear in Plotmaker.
It's a LONG standing question that I'm sure a search would turn up dozens of posts about.
Tom Waltz
Steve Jepson
nasty little thing about PlotMaker. Here is one of the things I do to compensate.
Drag a copy of what you want on the ghost story off to the side. Explode it. Delete the fall out you don't want. Group. Change color. Put on sperate layer. Sometimes I even save it as a .gsm.
There are some other ways to compensate for no ghost stories in PlotMaker. None of them are as convenient as having the ghost story from ArchiCAD show up.
__archiben
nasty method! far easier, not to mention keeping the data live, to place a different view of whichever storey you want to ghost below the drawing you are placing in plotmaker.
ensure the top drawing is set to transparent, and change the pens on the bottom drawing to suit your needs (fade-back, punch-out, bit of both, whatever) . . . all you need it two hotspots to line them up (one on each drawing).
HTH
~/archiben
b e n _ f r o s t
Steve Jepson
Yes. That is the proper way to do it. It will also give you better control than the settings available for a ghost story in ArchiCAD.
The only reason I ever use other methods for a PlotMaker ghost stroy is because of the increase in update time for PlotMaker with extra drawings added.
Updating adds a serious amount of time to every project I have used PlotMaker for. Having to do it 100 times or so is not uncommon. I am always looking for ways to reduce this time. It makes PlotMaker not worthwhile for me on small projects where the advantages of PlotMaker are not very important.
aahatimo
is this still true w/ v10?
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
Ghost stories still don't print, but the drawing updates are lots faster so overlaying drawings has no downside and the advantage of better control.
