Project data & BIM
Problem with layers
I have a problem with ArchiCad, and that is that the layers I created and locked turn themselves off when switching from 2d to 3d model and vice versa. If anyone knows what that is, I would be very grateful. thank you
5 REPLIES 5
Lingwisyer
Guru
Filtered 3D (F5) instead of 3D Window (F3)? Your windows are reverting to their original layer combination?
AC22-28 AUS 3001Help Those Help You - Add a Signature
Each TAB that you switch to can remember its own settings.
It is possible to transfer settings from one tab to another.
Maybe have a watch of the video here and it may help explain things.
https://helpcenter.graphisoft.com/user-guide/76309/
runxel
Hero
You can keep the tabs in sync however.
After activation in the settings you can right-click and link them. They will then have a colored line above the name.
This should ease working for you.
Lucas Becker | AC 27 on Mac | Graphisoft Insider Panelist | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
This setting in the Work Environment.
Stress Co_
Check David's post here:
https://archicad-talk.graphisoft.com/viewtopic.php?t=55022
Marc Corney, Architect
Red Canoe Architecture, P. A.
