mikas
Properties import from excel fails
I am trying to import properties from excel table without success. I have gone through some hoops allready and can't figure out what is the problem. It´s a teamwork in SaaS (AC27), and I have reserved _everything_ for me to do this operation.
File, Inteoperability, export and import properties, I think this is the right menu to do this, but all I get to is an error. "Import is not allowed. Values missing or not available.." Saving and reading the error report did not help.
Trying to bring in that Ikkunatyyppi (IA, I, and so on) column from another xlsx, exported from an earlier version of the same project (AC27 file, same version).
Please see attachments.
AC28, Rhino8+Grasshopper, TwinMotion • Mac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RTX4080FE 16GB/W11ProWS
1 Solution
Xandros
Hi
are those elements you're trying to import the properties to properly classified?
The "---" symbols in the column Ikkunatyyppi  are often indicators for a property that is not visible to the used classification
ArchiCAD 27 GER / Win10
Intel i9-9900K / 64GB RAM / nVidia GeForce RTX 2080 Ti
Go to post
2 Replies 2
Xandros
Hi
mikas
Thanks, good tip.
I went on examing about it, thought allready I had found some wrong classifications, but out of the blue the AC interface decided to lock up on me. All greyd out. I can't find AC resources stuck on windows Task Manager, so maybe I'll just have to wait a little bit it to wake up again, sigh. Or bummer, to say at least.
I'll update later..
