2006-07-07 04:32 AM - last edited on 2023-05-30 01:01 PM by Rubia Torres
2006-07-07 05:00 AM
2006-07-07 05:12 AM
2006-07-09 04:07 AM
Link wrote:. . . but it's position is. more crazy graphisoft logic.
So it's visibility is not stored with a Palette Scheme.
2006-07-10 04:22 AM
~/archiben wrote:yeah i had noticed the hole it left ... well i guess they cant be expected to rememberLink wrote:. . . but it's position is. more crazy graphisoft logic.
~/archiben wrote:done ... thanks for the tip!
what you can do, and what i do myself, is add the quicklayers commands to atoolbar(or create a toolbar specifically for them). toolbars aresaved fully into the palettes scheme in the work environment. the buttons on a toolbar are slightly smaller than on the quicklayers palette-that-isn't, but you soon get used to it . . .
2006-07-10 01:07 PM
2006-07-10 01:24 PM
It is necessary to do the same with the palette "active layer", but I do not find the way to do it.This may help...
2006-07-10 01:29 PM
2006-07-10 01:34 PM
2009-10-07 02:48 AM
Link wrote:Still the case with 13. Can someone from GS explain this?? How can this be either so tough to program or just ignored all these years? Ditto for Element Info and the others. Good grief.
According to Graphisoft terminology, the Quick Layers palette is not officially a palette. So it's visibility is not stored with a Palette Scheme...Crazy, but true!
