Project data & BIM
Quick Layers Palette ... wont stick with WE
owen
I am having a problem getting the Quick Layers palette to stick with my Work Environments. It is saved with both of the WE's I use but whenever I start AC or switch between the two this palette always turns itself off - every other palette is fine
I had the same problem in v9 but couldn't be bothered posting about it but ive finally had enough of it. Any ideas why this one is being so stubborn?
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
23 REPLIES 23
ksymons19,
RE: offset in new toolbar: see image, are any of these what you need?
Snap
Scott Bulmer
L wrote:
I'm experience a similar thing with QL palette. It´s there but it´s dead. Especially after switching between app´s. I have to switch it off and then on again.
This is to confirm the same issue for me. It is definitely a bug.
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
It's happening to me too, though intermittently. Has anyone reported it?
Dave Jochum
Hallelujah! The Quick Layers palette finally sticks in AC 16! Still the same goofy non-standard size, but progress none-the-less.
Unfortunately, the Find & Select palette still doesn't obey properly.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.3•AC 28 Silicon (latest build)
