Steve Jepson
Quick Layers Palette
My Quick Layers palette keeps quiting. I have to turn it off and then back on to get it working agian. Does anyone know what could make it stop working?
5 Replies 5
I was bugged by similar issues in 12.
In 13 I made a custom toolbar for it and added it to my work environment.....
Laura Yanoviak
ditto -- I say "BUG"
Steve Jepson
I made a shortcut key to toggle it on and off so if/when it quits on me I can just click the letter L instead of having to go through the menus.
It works.
Laura Yanoviak
Let us know if it works because accessing via the toolbar is a bit of a pain (the icons are totally different, for one) -- LJY.
Arcadia
Yep same things happen to me too. Did in V12 too. Whenever you open a new file its like the palette has to be 'reset' by turning it off and on. I added the button for it to a custom toolbar I have set up so I can quickly click it off and on again. Other's have done similar things clearly. Minor annoyance but something GS should fix in the next hotfix surey.
V12-V27, PC: Ryzen 9 3950X, 64g RAM, RTX5000, Win 11
