2008-09-27
		09:21 PM
		2023-05-26
		09:03 AM
			Rubia Torres
2008-09-27 10:16 PM
2008-09-30 04:08 AM
2008-09-30 05:38 AM
2008-10-01 01:58 PM
Thomas wrote:if you select the module on plan (grouping on) and right click or go to file/external content you'll see an option available called hotlink module settings. select that and you will be presented with the window you get when hotlinking files, so you can see the 'master' layer for the module (and change it if you so wish) and also the module's elevation in the z axis... all the settings you are presented with at the beginning are there
I have also asked for the hotlink's Master Layer (the one you assign the hotlink to) to be displayed in the Hotlink manager so you can find it afterwards if you forgot to take notes or rename the layer before linking. No luck.
2008-10-01 02:45 PM
xristina wrote:
if you select the module on plan (grouping on) and right click or go to file/external content you'll see an option available called hotlink module settings. Select that and you will be presented with the window you get when hotlinking files, so you can see the 'master' layer for the module (and change it if you so wish) and also the module's elevation in the z axis... all the settings you are presented with at the beginning are there
   So it has to be selected while grouping is on – when not, it isn't even a
