2023-02-24
09:53 AM
2023-05-11
12:14 AM
Gordana Radonic
We have a master file - orientation 0° and a hotlink file that is rotated 90°. Unfortunately, the zonestamp-label is also rotated 90° in the master file. I have tried to adjust the angle of the room stamp itself, but unfortunately it is always rotated 90° in the master file. Is there a hidden setting or do I have to make the hotlink file the same orientation as the master file?
This settings didn´t help:
Thanks in advance!
Solved! Go to Solution.
2023-02-26 06:56 AM
Does it help if you set it as fixed angle to screen in the module?
Maybe it will link into the master with the same angle to the screen.
2023-02-26 06:56 AM
2023-02-27 02:04 PM
That was it, even though I was so sure that I had already tried it. Thank you so much!
