vali_metes
SAF import/export for Archicad
I am trying to create a workflow around the SAF translator for Archicad and otehr strutural analysis software that support SAF.
In the first run I've tried out in Model Compare my current model against another .pln model imported for the second slot, everythign works fine.
When tryin to compare my model against a SAF (.xlsx) model exported from an identical Archicad file with the columns modified, it fails to show the second model, I can only see my current model.
I was using the default SAF translator used for Archicad 29.
My model is red, the second mdoel shoould be blue-ish.
Thank you,
Operating system used: Windows 10
1 Reply 1
Are you doing the exact steps described in the Help files:
https://help.graphisoft.com/AC/29/INT/index.htm?rhcsh=1&rhnewwnd=0#t=_AC29_Help%2F081_ModelCompare%2...
