Sheet Index
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2010-08-27
01:22 AM
‎2025-01-14
10:27 PM
• How do I create a linked revision number?
• Where is this revision number edited?
• How do I link this revision number to the Sheet Index?
- Labels:
Revision Management
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-08-31 11:44 PM
The PUBLISH status occurs AT THE TIME of hitting PUBLISH... so the INDEX in ARCHICAD environment will NEVER SHOW ANY PUBLISHED LAYOUTS... But, when you hit PUBLISH the status is CALCULATED and the index PRINTS to PDF as you would expect...
Not very useful if you need to plan your sheet layout around the length of your index, but it does work.
Once you've published, it will display in the INDEX WINDOW correctly (for the LAST PUBLISH INSTANCE).. Next time you publish, it will update again...
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-09-01 01:47 AM
A
Director
Thomson Architecture, Inc.
Instructor/Lecturer, Toronto Metropolitan University Faculty of Engineering & Architectural Science
AC26/iMacPro/MPB Silicon M2Pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-09-01 01:55 AM
I also learned that each LAYOUT has a STATUS where you can just type in any text... I suppose if you go thru each layout and apply the status PUBLISHED, you could "fake" it...
I'll admit, this is a horrible workaround and wrought with potential error...
Visual Frontiers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-09-01 02:16 AM
Director
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-09-01 02:22 AM
LAYOUT SETTINGS
TAGS AND CATEGORIES
STATUS
Visual Frontiers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-09-01 02:27 AM
andyro wrote:I should mention that just after you PUBLISH your layouts, you can go back to the INDEX and they will display as just published... but as soon as you do something else, it's go blank again.
Thanks - will try! Was hoping to get sheet index up long enough in the drawing's source view to export as a text file to send elsewhere. (bid docs, front end).
A
Visual Frontiers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-09-01 02:44 AM
Director
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-09-01 03:28 AM
andyro wrote:Not really.
Yes exactly. IMO that is a BUG not desired behaviour.
If you haven't published your layouts how can Archicad tell you what is going to be published?
It would be like knowing the Lotto numbers before the draw - that would be nice though.
I agree though it should continue to show the last published layouts.
Or maybe there should be a way of showing what is set to be published - I can't say if this is possible or not as I don't actually use it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-09-01 05:05 AM
Director
- « Previous
- Next »
- « Previous
- Next »
