Project data & BIM
Slow updating of Hotlink Manager window
fuzzytnth3
In the last few days or so I have noticed that AC14 is now very slow to update the Hotlink Manager window. It's also very slow at just doing the File Menu "Open" command just to go and open another drawing. Whether these two things are related I have no idea but I wondered if anyone else had this problem and found a way to sort it?
Link to a movie of how slow it is below...
https://dl.dropbox.com/u/399074/sites/trapdoor/hotlinkmanslow.m4v
And the link below is to a movie when you repeat the command it then loads up at the speed I usually get
https://dl.dropbox.com/u/399074/sites/trapdoor/hotlinknormal.m4v]Normal Movie
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
I have experienced the slowness in opening a file. The prefrences had become corrupt. Deleting them solved the problem. I wonder if it would also help the module loading time.
fuzzytnth3
Thanks for the suggestion I shall give it a try
