Is there a way of getting a summary or a list of all the pens used in the project? We are trying to match these pens with autocad pen set but I only need to do this for pens used within the project.
is there a way of exporting a list of the pens used?
You can use the Attribute Manager to see the pens used in the project (I think this also includes pens used in the default settings of the tools). You can export a text file of the pens, but when I did this, the In Use column was empty.
