Shub Umrani
Survey Co-ordinate
Hi all,
I am try to get the survey points to work on a site.
I have set the survey coordinates and also the file origin marked with X is giving me the origins required but when I try to plot at different coordinate the northing does not match.
If anyone had a same issue or have solved a problem alike would appreciate your help.
Attaching some of the images to get a clear picture.
Setup info provided by author
Can you check a distance on your plan and see if it is the correct size.
Clearly the Easting is in line and is correct.
I am assuming the plan is not scaled to the correct size.
Shub Umrani
Thanks a lot Barry. I'll try to check it . 😁
