Project data & BIM
Tab Bar Missing? (AC20 Build 3012)
I'm using AC20 Build 3012 (full commercial version) on a PC with Windows 10. For whatever reason, I don't have the tab bar so I have to keep switching back and forth between views through the "Window" menu.
Typically you'd get your tab bar by going to Window>Show/Hide Tab Bar, and you can set your tab bar preferences under 'More Options' in your work environment settings.
Neither of these options are available to me. It's not that they're greyed out, they're just literally not in any of the menus.
How do I get my tab bar up?? TIA!
David Maudlin
jackiebiswas:
The Show/Hide Tab Bar command could be missing from your Work Environment (particularly if your WE was imported from an earlier version), so check Work Environment > Command Layout Schemes > Menus > Window to see if it is there. The current AC20 build is 8005, the Library Build Number is 3010.2, so check if your build is up to date.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Yes, just load the standard 20 Work Environment.
Try not to use custom WE from older versions, as the new commands may be missing.
It is best to re-create your custom WE for each version if you need to.
