2021-02-28 07:10 PM
2021-03-01 10:07 AM
2021-03-05 08:35 AM
2021-03-05 09:14 AM
Sjuzi wrote:In the Library Manager you will see there is an 'export selected library items into local folder'.
Yes I have the same problem. I did create new materials and all textures are in embedded library. Is there any way to move it to Archicad library or how can I fix it? Please help![]()
2021-03-05 09:21 AM
2021-03-08 06:34 PM
runxel wrote:Hi! We dont have that many objects in the embedded library and dont use custom textures
Any chance the project is full with textures and objects in the embedded library?
2021-03-08 06:34 PM
Barry wrote:Thank Barry, we´ll try that
Once you have exported them, you can load that folder as a linked library and delete the files from the embedded library so you don't have duplicates.
2021-03-09 01:31 PM
2021-03-17 08:18 AM
jl_lt wrote:Hello,
Hi guys! each time we finish a project we take what might be used in the future and put in the template. But in this last project we made a complete revamp of our layer combinations, layers, pen sets graphich overrides, and material names, and layouts and a lot of stuff really. So basically this new project becomes the new template. The problem is i cant get the template file below 600mb.
Any ideas on how to reduce the file size? last resourse of course is start from scratch, but takes days to finish this kind of stuff
thanks!
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-08-10 01:57 AM
