The world should rotate around my project!
Don't we all feel that the world should bend, and revolve our project? I think so to. . .
I'll cut to the chase. . .I've usually been setting up my projects with the main or ground floor and level 1, and then I use the layer settings to set up my foundation at level -1, and I've been putting my plot or site plan in at level -2. Usually, I just cut and paste what I need from the foundation for a 'footprint' on my site plan, and just shove it over way off from my elevation and section lines. Here lately however, I've been thinking. . .doesn't ArchiCAD have an option that allows me to change where north is? What if I wanted to draw my lot on level -2 directly underneath my foundation plan, so that if I change my foundation, I don't have to cut and paste for every change? Is there a setting that would allow me to say that up on my screen isn't north. . .this time up is N 89D 48' 32" E? Or even better perhaps a library part that allows me to simply rotate the North arrow in my project? I know that this can be done in the sun settings dialog, but am I the only one that thinks that a bit easier 'orientation' (for lack of a better word) might be a great idea?
And. . .for those of you that say, "Bah! Just cut and paste man. . .it's not so bad. . ." I DID cut and paste a lot in a CAD program once. . .it was called AutoCAD. . .
12 Replies 12
This is the one that I use, I purchased it from Objects Online.
Note: I haven't fully tested it on ArchiCAD 10 extensively, but I haven't had any trouble with the tool at all. It seems to migrate seamlessly into version 10.
Stress wrote:
Where did you get your custom survey line "part"?
It could be the one I was passing around about three years ago. The name was "Survey Dim ML7.gsm" The ML7 part is my initials plus the AC version number. I haven't updated since, but it still works.
Anyone who is interested in receiving a copy, please send a PM with your e-mail address and I will send along the PLA. It is about 1.5MB and includes instructions.
EDIT: I see that it's not my old one, and the Objects Online one has more features. I'm still happy to send along the freebie to anyone who wants it.
Link
Marc said:
I know there is a North Arrow library part that rotates to "North" as set in the 3D settings.....
Due to popular demand (from people just like you! ) that is available in the standard AC10 North Symbol 10 library part. It now has the parameter 'Follow Project North' that sets it. Yay!
That's Daniel's part and is very user friendly, as are all of his parts!
Cheers!
Link.
