Project data & BIM
Tracker Length Measurements
I seem to have changed the tracker window to display Length H and Length V when using the slab tool. Before it read length and width. Is there any way I can change it back? I just need this program so I can make a 2D drawing of a greenhouse. Thank you for your help!
I should mention this is ArchiCAD 10.
Link
Options>Work Environment>Tracker and Coordinates Input>Show parameter tags. Is that what you're referring to?
Link.
No, I can see the tags fine it's just they say something different than they used to. Like if I was using the slab tool it used to say Length:30' Width: 30'. Now it says Length H: 30' Length V: 30' for example. I don't know how I changed it but maybe I should not worry about it! Thanks for the response. I'm kinda a green horn when it comes to cad software.
