Turning Off the Reference Layer back in the plan view
Et al,
While in Layout Editor, I clicked "Open source view with layout as reference"
IT WORKED!
So how do I turn if off?
And why is there not a single word about this in the help menu, or on line?
I know it can be turned off because it disappeared as if by magic. I certainly have no idea what I did to turn it off.
2007 iMac 24 the terrible, ArchiCAD 11 latest updates, of course.
Thank you in advance.
2 Replies 2
Read in the Help about Virtual Trace, Trace and Reference, etc. It is all there. You will want the Trace & Reference palette open for easiest use - just click the upper left button to turn the reference off.
Thank you all. It was so easy I didn't see it.
And a special thanks to you, Kevin.
