Turning Off the Reference Layer back in the plan view
Et al,
While in Layout Editor, I clicked "Open source view with layout as reference"
IT WORKED!
So how do I turn if off?
And why is there not a single word about this in the help menu, or on line?
I know it can be turned off because it disappeared as if by magic. I certainly have no idea what I did to turn it off.
2007 iMac 24 the terrible, ArchiCAD 11 latest updates, of course.
Thank you in advance.
Read in the Help about Virtual Trace, Trace and Reference, etc. It is all there. You will want the Trace & Reference palette open for easiest use - just click the upper left button to turn the reference off.
Karl
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thank you all. It was so easy I didn't see it.
And a special thanks to you, Kevin.
