2004-10-12
03:16 PM
2025-07-17
03:50 PM
Molinda Prey
2004-10-13 11:28 AM
ejrolon wrote:as far as i'm aware this is saved with the file not the WE . . .
Is there a particular reason that every time I open AC09 the navigator defaults to "View Sets" instead of "Project Map"?
I have tried almost all of the settings in WE and can't seem to find a setting that will change that to "project map". IMO it is more productive to start the Navigator in "Project Map" than "View Sets"
Why does WE reports "Palette Scheme Options" always as custom even though I have defined my settings and it is a new file and I choose default and have not changed a thing?because some of the palettes don't fall under the WE rules of engagement, but
Why does the 2D and 3D window settings are not saved with the WE scheme? If I choose a different WE scheme the drawing windows change shape and size and they stay that way even when choosing other WE schemes.i think the drawing window size is only affected by the WE at start-up or when pressing the maximise button.
Why when opening a new drawing the default Set up Work Environment is set to last profile used and not default? Shouldn't default be the Default? I can understand that when creating a new project after having another project open you might want to use the previous project's settings but IMHO when you define a WE it is because you have chosen the way you want AC to start and that should be the starting point.i agree, it's an a&*e-backwards way of expressing it, but if you don't change your WE very often, the 'last used profile' will always be your default anyway.
2004-10-13 03:25 PM
~/archiben wrote:No, it does not. It always goes to View Sets.ejrolon wrote:as far as i'm aware this is saved with the file not the WE . . .
~/archiben
