Project data & BIM
Wall schedule
Polar Bear
I am making a wall schedule for estimation and after adding renovation status, the schedule shows other items than walls.  Why is it so?
Thanks
Regards
pb
Screen Shot 2023-02-20 at 17.57.58.pngScreen Shot 2023-02-20 at 17.58.05.png
Archicad 25 - 5010
Macbook pro 13" /Big sur 11.4 + External 4K 27"
Gerry Leonor
try adding the brackets "(" and ")" before & after the Renovation criteria, so it reads like:
(Renovation status is Existing or Renovation status is New)
https://discord.gg/XGHjyvutt8
Gerry Leonor
Polar Bear
WORKING. THANKS!
Archicad 25 - 5010
