Rakela Raul
Warning Popups
Is there any way to eliminate all warnings:
'errors occurred last operation" , "hotlinks not found" (this i know how to kill)
, "jpegs/pdfs not found at this location", etc.
When i open a file i dont want to perform more than one click, regardless of all the file errors....i do recognize that warning are a must for my own good, but too many clicks !!
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
23 Replies 23
Deviz wrote:
Archisuad, how did you fix it if I may ask?
Archisuad may not remember if he is still in the forum.
That post was over 6 years ago.
When anonymous errors pop up you could try isolating them by turning layers on and off - this may make it easy to find the offending element.
I also like to marquee an area and view it in 3D (this usually triggers the messages as well).
No error marquee another area and view that in 3D.
Use the marquee together with individual layers and it can be fairly easy to find the problem.
Cheers Barry,
that's something I did myself in the past and didn't think to do now as well.
I found what was causing the error. It was a wall... ?! A bit surprised but happy as it's an easy fix.
Thank you so much again
Claudio
Glad you found it.
Nope, unfortunately I didn't.
It's doing it again now!?
I've got someone from Graphisoft looking at that for me though.
