Project data & BIM
What are you teamwork backup settings?
Mats_Knutsson
We use the GS default and I try to figure out what are the best settings...
The pln backup is set on 1 day interval and save latest 10 copies so in theory two weeks of work can be restored day by day.
The BIM-project backup is fully automated and is set to every 6 hours and save last 5 copies.
What if I turn of .pln and bump BIMproject to the last 30 copies as an example? That would give me automated backup for two weeks and every 6 hours recoverable. Will something choke if I do like this?
BIM Project backup also keeps the Teamwork stuff which the pln backup doesn't...
Pros - cons?
And where can I change the default settings forPLN and BIM project backup?
AC 25 SWE Full
1 REPLY 1
Noemi Balogh
Hi Mats,
You can find our backup guides here, which I believe - can help in your decision as well.
https://helpcenter.graphisoft.com/knowledgebase/52663/
From technical point of view, I wouldn't recommend to enable BIMcloud to create automatic backups while most of the users are working - they will experience a huge performance decrease, because BIMcloud will use most resources to create backup files.
Kind regards,
Noémi Balogh
Community Expert, Admin
