2022-11-29
05:15 PM
2023-06-07
03:54 AM
Gordana Radonic
I see the MaterialCatalog.xml under the Ecodesigner folder.
I've created a bunch of new BM's and I winder if there is any way to reach the Physical Properties for my BM's in a text file or similar? I'd like to update the BM physical properties for many .pln files and would prefer bulking this. When I export the BM's as an xml I don''t find the physical properties...
/M
2023-01-11 10:20 PM
Hi @Mats_Knutsson,
Thank you for your query. In such situations, we recommend users with software development expertise to download our devkit from archicadapi.graphisoft.com. After registration, the platform provides the source code for an add-on that can help you achieve such results. If any questions arise in the process, users are welcome to consult in the Developer Forum. Otherwise, this workflow is not yet available out of the box.
Best regards,
Community Specialist | GRAPHISOFT SE
Need help refining your Archicad skills?
Check our Modeling knowledge base for the best workflow + tips&tricks!
