Window/Door Schedule "Master File"
Hi!
I've created window/door schedule per my need that I called Master File. Is there a way to transfer this to all new projects without making adjustments every time?
Thank you!
1 Solution
In the Scheme Settings Dialog you will find the Import and Export buttons. These can be used to transfer the Schedule Setup settings from one Project File to another. This works in case of any Project.
If you want this in New Projects, just open the Template File, import these settings, then resave as Template File (*.TPL format).
Go to post
Thank you!
